Mazda Engine General \  Witch truck?
Witch truck?
views 1061
replies 15
following 6
will   +1y
The 92-93 B2200 Comes FI with 93 hp
or The b2600 89-93 121hp G6 motor
i want one of them i would really like the b2200 but you never see then fi but i hear the G6 is all around better, but the F2 has alot of upgrades.
elbine69   +1y
Get the FI b2200. The b2600 engine is junk.
will   +1y
yeah but the problem is locating one for about 2k.
mazdamandan   +1y
I hear the 2600 goes through head gaskets, like crazy, almost every build on this site on a 2600 starts by needing a head gasket
why not a FE3 motor? fi, dohc, search it on mx6forums.com to learn about it
will   +1y
because i dont want a swap, and i need a new daily and i would swap it if i had a FI already and it was direct bolt. im punching my self in the balls doing the 2.3l thunderbird turbo motor into my project atm
mazdamandan   +1y
gotcha, I'd go with the b2200 for a daily
My only complaints about this engine is the loud lifters, and shat carb and emissions crap, and low power with a weber it should be reliable though
mazdamandan   +1y
t bird swap , thats a new one to me,does it bolt in?
will   +1y
No, you need to make your own mounts its a fairly easy swap we already had it in a truck so its simpler to put into mine. You need to custom fab your hood, places for intercooler. you can keep the ac but its harder. You need to get a custom drive shaft made.
oldspice213   +1y
t bird swap sounds pretty crazy my friend used to have a supercharged one he got from his pap
90-b22dawg [andrew]   +1y
when i read the title i was thinking the truck was under a spell or something "WITCH" truck
