Mazda Engine General \  HELP!!!
HELP!!!
views 784
replies 2
88hawaiianb2200   +1y
i got a crazy oil leak and i can't really determine where its coming from. the leak seems like its just streaming off the crank...do the crank seals usually go bad on these trucks?
i was wondering if anyone had an engine diagram cuz it looks like its coming from either the crank or the gasket thats right near that but i have no idea what that gasket is. please advise!!!
thanks
rreyna   +1y
crank seals are notorious. i was leaking a quart every 5 days!! I replaced crank and cam seals when i did water pump and timing belt. Good Luck
nssj   +1y
are the cam and cranks seals on a b2200 the same?
ordered one of each from rockauto, got 2 of the same part #...
rechecked site:
some brands, same part number for either cam or crank seal,
other brands, 2 different part numbers...
Id rather know i have all the right parts before i tear into the timing belt...
thanks
