fuel injected mazda??
jealousonesenvy avatar
jealousonesenvy
ok my friends got a mazda that came fuel injected. What fuel pumps can be swapped on? i believe its the same engine from a 626
jimbeater avatar
jimbeater
ya know whats funny, i think 9/10th's of the fuel injected trucks came to canada... i keep hearing how it's like a myth that there were factory b2200 fi models... truth is is the opposite up here... there's like 1/10th of these things that are carbed... well i'm sure there was more at one point, but as an 'average persons' (read-doesnt care really what they are driving, so long as it gets out of its own way...) daily beast, and living without a pacesetter header and webber (what i hear makes the carbed engine tolerable), most people probably scraped them pretty quick.
from what others say and research i have done, there are many variations of this engine... different intakes from front wheel to rear wheel drives, different heads, and then the f2t in the mx6 and probes...
as far as fuel pumps, you may have to find one that fits in the stock fuel sender, or look at modifying, or a new tank, sender and pump all at once. i'm sure there are some that fit in place of the stock that are stronger.
jealousonesenvy
On the fuel injected models are the fuel pumps the same in the tanks? or could i use one from a b2000 or b2200 or mx6 626 mx3? non fuel injected??
jimbeater avatar
jimbeater
i dont think b2000 came fuel injected, so a no on that one. an mx6/626 fuel pump (for a fuel injected 2.2, not the turbo 2.2, although that would probably still work... just more pressure, but dont take my word for it working ...) is more than likely the same part # as a b2200 part... but likely not the sender.
it would have to be a fuel pump for a fuel injected vehicle for sure... i'm pretty sure a carb fuel pump doesnt flow enough pressure... could be wrong though.
badchicn (rick) avatar
badchicn (rick)
I own two of them. One has the factory in tank pump and the other has a generic electric fuel pump from a chevy truck (90's Fuel injected model) This pump is nice, but a little noisy due to it being mounted outside of the tank.
jimbeater avatar
jimbeater
thats cool to hear! so the truck with the fuel pump out of the tank, does it use the carbed truck sender?
