New water leak
New water leak
ridinlow84
So I found out that the water was coming from the intake manifold gasket. I replaced the gasket and the O2 censor. Now that its been running a little bit, I seem to have water coming from the motor somehow. It's coming from the front bottom of the engine near the lower pully. I think it could be the rad hose or water pump. Ithought it could be the head gasket, but the water is to present. If you guys have any suggestions let me know, all info will help. Thanks.
rbriggs's avatar
rbriggs
could be, pump was replaced? if so were the gaskets damaged during instalation? Or... if your trucks like mine and dont have ac... could be condensation lolz, but i dont take you for a fool so no, but could be condensed water vapor from the exhaust. It's condensing inside of the exhaust system then leaking out wherever it can. It's normal if so.
90-b22dawg [andrew]'s avatar
90-b22dawg [andrew]
sounds like water pump.
rbriggs's avatar
rbriggs
yea
kia swap
last post by Brody +1y
51
