Mazda Engine General \  Mazda B2200 weber carb issues.
views 5271
replies 1
following 1
digerati   +1y
During Spring break 2010 I installed a new Weber carb and header into my truck and I just cant get it to run correctly.
Going down the road its fine but it will not idle correctly until its completely warmed up and even then, I cant let it idle through a level parking lot. IT wants to lope and jump, like its not getting enough gas or something.
Used to, before the weber, I could let of the clutch and it had the strenght to go and not choke out. NOw I have to be sure to give it enough gas so that it will not die.
Its hard to explain so I attached a video clip. In the clip I am barely giving it gas and you can see how it wants to quit running.
Please help.
digerati   +1y
I solved it. There is a jet idle screw under the breather that I adjusted.
