ok i dont know if i spelled that right and incase you dont know what im talking about let me explain.. SOMETIMES when i drive my truck for a while when i go to turn it off it acts like it is trying to restart itself.. it almost dies and then sounds like it gets fuel again and trys to start back up.. sounds like shit and only does it sometimes.. what the hell is the problem.. i have a 2.2 carb has a weber on it.. i only run mid or high grade gas and always put a fuel additive in it.. other then that the motor is strong and runs very good.. like i said only does this sometimes.. tell me how to fix this please..
fastonthetrack
Mine does the same thing.. cant figure out why!
sahankaface
maybe running to rich?????
immortal1 (linn)
Combination of rich idle mixture and higher than needed idle speed. Many older carbed vehicles had a small solenoid for an idle speed stop/adjustment - when the ignition was turned off, the solenoid collapsed and effectively closed the throttle plates. Engine stopped every time.
Not all carbs / engines need them but my guess, in your case is a lower idle speed and slightly leaner mixture will solve your problem.
shellhart
ok how do i do that? i dont know shit when it comes to motors lol.. be as simple as possible i really dont know anything about motors so the more simple the better
immortal1 (linn)
Will probably have to get back to you with some pics. Kinda hard explaining with text only. A pic of a Weber would be useful about right now, LOL
shellhart
ok thanks for helping just when you get some pics let me know
sahankaface
sorry can't help don't know much about the webers i know on the stock nicky carbs they are on the side
shellhart
anyone know how to do this that can help me?
shellhart
also have been told that it could be a timeing issue. does that sound like it could be a problem?
