Need help.. 22 won't start
eric_duce@yahoo.com's avatar
pockets's avatar
pockets
Hey all...
Ok so I picked up a 91' b22 from a buddy of mine a few months ago. It ran like a top till the other day. I saw that it was over heating so I quickly pulled over to let it cool. After a while i pull some water back in it but it would not start back... I went home got the trailer and towed her to the house. I changed the water pump, head gasket, and timing chain here at the house over the past week. And still nothing!!! Idk what in the world is going on with it.. Anyone else ever have this happen? What should I be looking for from here?
Thanks a bunch.. -Eric
do a compression test see if you blew a head gasket
krunkelton
so it over heated and you replaced the water pump, tb, and head gasket. or the other way around.
anyways it could be a head gasket, your timing can be off, or cylinders are dead
pockets's avatar
pockets
Yes.. it over heated first... then I changed out all the stuff
thebeaumartin's avatar
thebeaumartin
ok well start with having a look at fuel,fire and compression test and recheck the timing
kia swap
last post by Brody +1y
51
