Mazda Engine General \  Installing Power Steering
views 6343
replies 10
following 7
addiktion   +1y
ive got an 89 b2200 with manual steering and i hate it. can i please get some help on how to install power steering, im new to the mechanical side of things. thanks
dragginmazda86 (dave)   +1y
Ive added PS to a few mazdas before, its fairly simple to add. You need to find a donor truck, make sure its a b2200 like yours cause the b2000 pump bracket is the only thing that is a little different. Grab the steering box assembly, pump assembly with bracket and bolts, fluid lines, and dont forget the U shaped cooler line that bolts to the frame under the radiator.
addiktion   +1y
thanks i will try and track one down, is there anybody who has done an actual tech write up on the install?
baggedbmy93mazda   +1y
would one off of a b2600i work on his truck.......just trying to help out. i have a front clip from my old b2600i that has all of it and it is useless to me......
zaib75   +1y
bump and please someone post power steering box pics
does power steering works if the pump belt brakes or pump failure
I want to install power steering in b2200 89
mercilessltd   +1y
The pump will not work without the belt. Defeats the purpose of a pump when there's no pumping involved.
I can post pics of my B2000 at some point this weekend. Bracing may be slightly different, but the general idea should be the same.
I can let you guys know of anything odd I find when I do my motor swap. I'm putting my 2.0L into my B2200, and taking my power steering as well.
spacemonkee23   +1y
I just did this using a donor truck at the JY, had the pump rebuilt bec it was leaking, as dragginmazda86 said take everything out of the donor truck as a complete unit. I also took this time to replace all the steering components because they were shot. It was a great upgrade. Unfortunately my phone was stolen before I could put the pics onto my PC but I will take some pics of it when I get a chance. I don't think the 2600i will work because its a different block, make sure its the same model as yours.
zaib75   +1y
I haven't a Mazda engine with me so can't say anything about block I have a Toyota 3sfe in my Mazda and pump fitting is not a problem for me I just want to see the power steering box which will direct fit on my Mazda b2200 89
spacemonkee23   +1y
I just took a pic of what I installed its the best I can do for now.
Hope this helps.
zaib75   +1y
very good man you posted same photo what I had in my mind
now I have a idea that how it looks
suggest for info will any Toyota or Nissan ,Mitsubishi steering box gear will work on Mazda?
