Mazda Engine General \  VALVE TRAIN NOISE
VALVE TRAIN NOISE
views 3197
replies 2
following 2
mattclark08   +1y
i came across this info on the net. i kno it says 93-94 but it may apply to 86-93 2000's and 2200's.
VALVE TRAIN NOISE ON MAZDA 2.0L ENGINES
Valve Train Noise On
1993-94 Mazda 2.0L Engines
The AERA Technical Committee offers the following information regarding a valve train noise on 1993-94 Mazda 2.0L engines. This noise can be associated with the Hydraulic Lash Adjusters (HLA).
This noise appears after the engine has been run at idle for a long period of time. The noise appears because air is entering the oil gallery. To prevent this condition from happening, Mazda had redesigned the oil pump plunger as shown in Figure 1.
HLA noise will appear at the top of the engine and is several times faster than that of the engine speed. Verify the complaint by running the engine at idle for a period of time not letting the vehicle overheat. If the HLA noise is present, replacement of the oil pump plunger is required.
To replace the oil pump plunger, remove the snap ring at the bottom of the pump as shown in Figure 1. Remove spring seat, pressure spring and the plunger. Replace the old plunger with the new plunger, Part #JF01 14 115. Reassemble the bottom of the oil pump in the reverse procedure of disassembly
NOTE: Follow instructions in the service manual for disassembly and assembly of the engine to get access to the oil pump for replacement of the plunger.
Revised Rocker Arm Reduces Lifter Noise On
1987-90 Mazda 2.2L (B2200) Engines
The AERA Technical Committee has recently become aware of a revised rocker arm that may reduce lifter noise on 1987-90 Mazda 2.2L engines. Generally this noise occurs only at engine startup, when the vehicle has not been used for a longer period.
When the engine starts, an insufficient quantity of oil reaches the hydraulic lash adjuster (HLA) to refill it. Therefore, the valve train may be noisy until the lash adjuster has been refilled.
The revised rocker arm features a larger oil passage to permit more oil to reach the lash adjuster. The previous passage was .031 in diameter, which has been enlarged to .078 in the revised part. Extended oil change intervals can lead to varnish and sludge buildup in the oil passage aggrevating the problem.
This engine uses a separate intake, Part #F240-12-131B, and exhaust, Part #F240-12-151B, rocker arm. Engines manufactured after September 1, 1989 use the revised rocker arms.
87_b2600   +1y
i had that as well but i kept tryin different oils till it went away. What motor oil r u using? and if it still dont go away just tighten the valve rocker arm bolt
mattclark08   +1y
The Lifters are hydraulic, non adjustable
