weber vac. advance
philopenopimp7@yahoo.com's avatar
weber vac. advance
91b2200(cody)'s avatar
91b2200(cody)
OK can someone please post a pic and show me the correct port to connect my vac advance?
i been runnin it without and it runs great! not gunna lie but the best it's ever ran. i just wanna give it another shot an see if i can get the vac advance hooked up correct. right now spinin em thru 2nd is easy but i just wanna see...
right now it idles great. an i can get up to about 5500 rpm
i think it should beable to go more right?
let me know.
heres pics of my motor as of today!
mistachalk
damn clean
dropped90(justin)'s avatar
dropped90(justin)
Damn that distributor is way advanced!!!!
-Justin
mazda88
hey where u find thicker wires at
91b2200(cody)
justin- i know man i might be a tooth off but im not sure. but the dam thing runs great.
mazda88- i got em at a junkyard for 5 bucks like new.
E
emjay
the vacuum advance needs to hook onto the intake manifold. There is a nipple that should be under the adaptor plate on the side of the intake closest to the passenger side fender. In your picture you can see it next to the egr block plate you made.
if your timing is too advanced it can cause combustion temperatures to get too high, which can damage your engine in the long run.
mazda88
damn u lucky
dropped90(justin)
Thats what i was thinking emjay.
-Justin
91b2200(cody)
can you point out exactly where in the pic your talkin about emjay?
dropped90(justin)
Its the nipple directly above the egr block off plate. You have a black plug on it right now with what looks to be about an inch of nipple still hanging out that the plug does not cover
-Justin
kia swap
last post by Brody +1y
51
