Mazda Engine General \  need HELP!!!!!!!
need HELP!!!!!!!
views 1003
replies 13
krash74   +1y
I just got my 90 b2200 with less than 100k on the clock. truck had just had a new waterpump and timing belt. it has a loud clatter from the top end but it doesnt sound like a rod knock. the only reason i baught the truck is a friend of mine said he had the same thing happen to his and the timing belt was off one tooth so i redid the timing belt and got it set perfect and the the truck runs like a champ but it still has a loud clatter? Any ideas? Was affraid it might be a spun bearing and i cant find a used motor anywhere. any help or ideas would really help this new to mini scene.........
Cusser   +1y
Are you sure that the sound isn't the valve lifters ticking, very common on these trucks. Mine's ticked most of the last 17.5 years since I got it(1988 B2200).
krash74   +1y
Sounds like a spun crank bearing but it doesnt do it at idle just when i rev. sounds terrable
krash74   +1y
Screw it. a v8 swap will be cheaper than paying to have my 2.2 rebuilt.
axel breaker earl   +1y
Get a mechanics stethoscope and find out where the noise is at.....it could be something simple and not a spun bearing. Have you drained the oil and looked at it, if you have a spun bearing (and the oil hasn't been changed yet) you should see some super fine aluminum bits in the oil.
krash74   +1y
The noise is coming from the top end and only when you accelerate. changed the oil today and black as hell but no metal shavings.
Well, it won't be a camshaft bearing, as there are none on these engines.......have you pulled the valve cover and looked at the valvetrain yet?
krash74   +1y
yeah, looks good and clean. just had someone else say it might be a cracked piston.
The truck looks great man! If I were working on it I would try to pin point the noise source first.......make sure it is not an accessory also.
jc50942   +1y
^this...but i t can get spendy...ill' have probally 4k in mine by the time im done.
