Mazda Engine General \  Tracking down a voltage drop on a 94' B2300
views 533
replies 2
following 2
stillwaterb23   +1y
Hello everyone i have a 1994 B2300 that i'm trying to chase a voltage drop on. I replaced a coil pack and plug wires the other day and still had intermittent starting, so i replaced the fuel filter as it was a bit clogged. The truck ran fine for a day or two and now it just cranks but wont turn over. I checked continuity of the inertia switch, good there. I cleaned and tightened all grounds in engine bay. The problem I have is that with the key in t he on position, i only get 8.9v at the fuel pump. Was wondering if it could be ignition switch? Thanks for your help!!!
newbiet   +1y
Check your power at the fp relay and if there's a fuse before it. Check the ground side of the pump also, may be intermittent bad ground. What's the battery voltage when you were getting that reading?
stillwaterb23   +1y
Battery voltage is just over 12v. I checked the fuel pump relay and the pcm relay and I have 12v in two terminals and 3-4 in the other two and just shy of 1 in the fifth terminal.
