change diffential oil
polisheminem@hotmail.com's avatar
fitbmx180's avatar
fitbmx180
how do you change the differential oil in a 92 mazda b2200? also what type of gear oil should be used
Cusser's avatar
Cusser
First, loosen/remove the FILL plug (just so you now you'll be able). I use a 24mm or 15/16 inch six-sided socket, typically put a band of duct tape around the bolt head, as I think this might be one of those strange 23mm bolt heads.
Then loosen and remove the drain plug. Then replace, and use a pump-top filler (screws onto gear oil bottle) to fill up the differential until it starts to seep out the fill hole. Figure 2 quarts gear oil, I use 80W-90 Valvoline.
And do your manual transmission similarly, same gear oil.
kia swap
last post by Brody +1y
51
