help
E
eroticlarry
Truck does not want to go in or out of any gears its a b2000 5speed
Cusser's avatar
Cusser
Get helper to press down on the clutch pedal all the way as you watch the slave cylinder rod, to see if it's actually moving the clutch lever on the transmission the correct amount.
My guess, and the first thing to check, is the clutch hydraulics: the clutch master and clutch slave cylinder. These are known weak points on these trucks (I've replaced mine every few years due to failure).
jenko
if the clutch hydraulics still work, rock your vehicle back/forward and see if it'll come out of/into any gears.
if that works pull her apart, seems like it's throw out bearing failure time on your side of the pond.
kia swap
last post by Brody +1y
51
