vaccumm hose needed
devinbusher@gmail.com's avatar
vaccumm hose needed
1986b2000's avatar
1986b2000
Does anyone know where I can buy the vacuum hose that goes from th brake booster to the metal tube that eventually connects to the intake? It has a valve in the middle im pretty sure. Any help is appreciated. Thank you. -Devin
sincitylocal's avatar
sincitylocal
You can go to the dealer and hope a new one is available, junk yard for a used one, or maybe someone here can supply one.
Yes, there is a check valve built in.
Cusser's avatar
Cusser
My B2200 (1988) has the brake vacuum check valve inside the rubber hose, has letters on it that say "To engine" or similar. I'd check but the B2200 is 50 feet away.
I have spares of those rubber hoses/check valves.
antneee
is there a check valve in the hose at the other end of the line (that goes into the intake manifold) or is that just a hose? 43-846 in the diagram
scotch
Just a hose.
1986b2000's avatar
1986b2000
Yes there is a check valve in there. It's part #43-640 in the diagram.
Thank you for the help everyone. I'm going to order a new hose from the link above.
kia swap
last post by Brody +1y
51
