Mazda Projects \  5.0 in the B2000!!!
5.0 in the B2000!!!
Mazda Projects
views 2548
replies 18
following 6
baggedmazda86   +1y
Ok first of all can I keep my stock rearend in my truck when I put that motor in? Or wat. I've ask before but I never got anything back.
mazda454   +1y
are running an overdrive transmission? the factory rears are geared really low unless you are running an overdrive trans. the 5.0 will not need to turn as many r's as the 4 cylinder did. i would prefer a ford 8" but then you to redrill the flanges to keep the 6 bolt wheels.
baggedmazda86   +1y
Are you askin if I have a overdrive trans on my 2.0 or the 5.0?
jc50942   +1y
First off...why would you put a ford motor in it? Waste of time..why do you ask? Because its a Ford....im just kidding. Thats really all i got to say. If you go through with this project, make sure you keep us posted with pics. I did a v-8 swap in mine and i would love to get some fresh ideas for the next one.
mtrain   +1y
Yes you can keep the stock rear end as long as you don't go crazy with the power, or do a lot of burnouts. You will have to get a Ford yoke to mate up to your drive shaft.
I've got a twin turbo 363 Ford engine in mine so I had to go with the tried and true Ford 9" rear.
Are you going carb or EFI? The carb setup will be simpler which is why I have it on mine.
baggedmazda86   +1y
Lol. Did you change your rearend?
baggedmazda86   +1y
Well the guy said I can have anything off that car I want and I heard it run and it has EFI. So I mite do that. I'm not sure yet.
jc50942   +1y
if it were mine id swap rear ends.....i didnt on mine but i dont need to....never really any launching stess on it so its not a big deal. At least i figured that would work for now. I do have a nine inch sitting out back if it ever does go out though.
mazda454   +1y
get the mustang rear end should be a 8.8
