Rear interiror panels -- cab plus
bradbush
How do I remove the rear side interior panels on my B2000 CabPlus? I'm putting in a new carpet, and it would sure be easier to get them off. I have them loose, and can pull them out a few inches at the bottom but how to get them totally off to make a really nice install? Thanks!
topless
Pull rear jump Seats! Remove rear wall first I think! Remove caps on quarter glass ! Remove upper interior trim! Then, remove lowers! Once you start it will be self explanatory! Doesn't take long and makes for easier n better job ! Good luck!
Cusser's avatar
Cusser
I pulled the rear seat back once. Remove the four bolt covers on the middle part. Then unbolt the seat back. Go from there.
bradbush
Thanks for the help. I was hoping not to have to get into the window hardware, but I think you've encouraged me that it can be done! Thanks for the prompt reply....
Cusser's avatar
Cusser
The window hardware is pretty straightforward though. Phillips head screws after plastic plugs are removed.
