Mazda Projects \  oil and water pump to be installed
Mazda Projects
views 2991
replies 13
following 5
alittlelow   +1y
so im taking on this task of installing a new oil and water pump on my 88 b2200 never done it before so any tips would be greatly appreciated thanks guys in advance
anguswilly   +1y
Why are you replacing the oil pump?
alittlelow   +1y
Well since Im already gonna be right there why not the timing belt is gonna be replaced also with new tenioners
Sent from my Desire HD using Tapatalk 2
Cusser   +1y
Combined R&R of timing belt and water pump is MUCH simpler than doing the oil pump.
I didn't even replace or remove my oil pump during my B2200 engine rebuild almost 3 years ago.
mazdatweaker_2   +1y
Unless you plan on removing the oil pan don't plan on replacing the oil pump. I don't think you can remove the pick up without doing that first.
anguswilly   +1y
Do not replace the oil pump unless it fails - and they almost never do, long ago I was running 19psi boost on my B22 and blew a hole straight through the #1-4 pistons - I rebuilt that motor and the oil pump was still fine (just cleaned it)
Leave that oil pump alone, it is not a "wear" item.
alittlelow   +1y
under further investigation I found out that my oil pan was leaking so I guess it will be easier to just take it off and clean it and replace oil pump at the same time so as I was pulling off the water pump there was a leak behind the oil pump also so what should i do at this point not replace oil pump
axel breaker earl   +1y
First you'll need to unbolt the idler arm on the passenger frame rail so the front drag link can be lowered enough to get the oil pan off once you get the oil pan loose.
Second, pull the motor-to-trans braces on each side of the oil pan.
Then remove all of the oil pan bolts, and start working it loose......it is glued on with silicone from the factory.......and it is ON THERE! Be careful not to scar up the oil pan, or bend it......use a putty knife and razor knife to slowly work on the silicone.......the front oil pan rail is actually the bottom of the oil pump, and it's aluminum, so be extra careful that you don't gouge the rails up there........the rear oil pan rail is the same also......aluminum. It is the rear oil seal housing and you want to be careful with it also.
Once you get the pan off, you can remove the oil pick-up tube, then the oil pump.........of course the harmonic balancer will have to come off also, and that 21mm bolt will/should be very tight.......you'll probably have to use an impact wrench to remove it, and when your putting it back on, you'll need to rig a way to hold the engine from spinning in order to tighten that 21mm bolt back down to 160 ft.lbs. or so.
Use the ultra grey silicone to re-seal the oil pan........DON'T use a oil pan gasket!! All gasket kits come with one, but don't use it, otherwise you'll have a oil pan leak within the first year.......these engines never came with a oil pan gasket.
You will probably need to unbolt the windage tray (between the oil pan and the block) and clean it good around it's perimeter and use the ultra grey on it as well, before the oil pan goes on.
anguswilly   +1y
And you'll need a puller to remove the lower TB pulley.
alittlelow   +1y
as i work through this process i just wanna say thanks to you all for all your help and i will post how things go thanks again
