Mazda Projects \  1990 B2600i SE-5
1990 B2600i SE-5
Mazda Projects
views 1382
replies 5
darkzero4u   +1y
Hi all I have a 90 SE-5 and took it to the shop to have them look it over and yeah I have my work cut out for me. Having 199621 when I got home and NOTHING done to the her there was a not wrong with it. The shop knows me well here and they say that I cant do any work on my own (as I have had about 5 cars in the past 2 years) I have a list of things wrong and the price tag (so far) is around $3500. the big price tag is the clutch at $1100. if I knew how to post a pic I would show you what the shop said I need to do I want to keep the truck I love it. any help on how to post a pic
Cusser   +1y
Question: so - is your clutch slipping, like the engine rpm goes up without corresponding increase in truck speed?
If so, you do need a new clutch. Separate is clutch master and slave cylinder, those will cause issues changing gears, common for those to go bad on these trucks.
If a new clutch is due, then the transmission must come out. Get quotes from transmission shops, other mechanic, etc., because $1100 is on the high side. My estimate would've been $600-$900, so shop around.
darkzero4u   +1y
I have got new price for it the shop said that the clutch was needing replace that it can go out at anytime.
sincitylocal   +1y
If your clutch is NOT slipping, your mechanic is lying to you. The pedal feel on a new clutch will be the same for the entire life of the same clutch. Even if it starts slipping, the pedal feel does not change.
If you got air into the hydraulic system, or you had master or slave cylinder problems, then the pedal will change.
darkzero4u   +1y
I do have master cylinder problems needs replaced had a different shop look at it today and was told that it should help to replace it
Cusser   +1y
Yep.
I remember my sister 30 years ago bought a Datsun truck used, I recommended that she take it to an import shop to have all the fluids changed. The shop called me, said the clutch was so ready to go that they were reluctant to even remove a leaky slave cylinder on it to fix that, said they were afraid they wouldn't be able to mount a new one on. Since the previous owner actually worked as a salesman at a local import dealer, he had told me that "his" shop had recently installed a new clutch PP/disc/bearing/etc. So I told the shop to "do nothing". I called the seller back, he confirmed the new clutch, said he even saw the truck on the lift with transmission out on his lunch hour.
Anyway, I took a look (no repair manual, etc.) I unbolted the clutch slave, it actually looked OK, the fluid leak was from the clutch master and had worked its way down the outside of the lines. I got a new clutch master or repair kit, fixed that.
Sister had the truck another decade, never once had an issue shifting, clutch slipping, clutch hydraulics, etc. So that ranks as the one of the three times a woman in my family was the target of a mechanic rip-off that I can officially confirm.
By the way, the others were my mom with a recall on her 10-year old Cadillac, dealer told her the heater core was leaking, $2500 fix. I asked her how big was the puddle in the garage, she didn't have any leakage and wasn't low on coolant. I told her to take it to mechanic I use (like once a year, but I've sent a bunch of new business to him), he tightened a hose clamp, and no charge.
The third was Mrs. Cusser took her "new to her" 1988 Suburban in for an ATF change at a transmission shop in 1995, as I'd never seen automatic before. Shop claimed the fluid was so black and bad that they couldn't do a change, all they could do would be to rebuild (actually disassemble and check for $150, and if you refuse a rebuild you get a box of parts) or put back the old fluid (like how do they retrieve that from R2D2 ?). I went there, they showed me pan shavings 9didn't look bad to me), I told them just to button it up. Anyway, after driving 50 more miles that day, I went to check her ATF level, found that the fluid was pink like it should be, so I called transmission shop to inquire how black fluid could become pink. They said they'd call me back to discuss, and it's been 21 years now, so I doubt that they'll call.....anyway, I did the ATF and filter change myself that they were afraid to do....was fine...
