Clutch problems!
xjoewhitex@gmail.com's avatar
Clutch problems!
xjoewhitex's avatar
xjoewhitex
Not sure where else to post this but it started last night, not sure whats going on. I was sitting still with the clutch to the floor in gear, and the truck just started to stall out and it died. Noticed I couldn't get it out of gear, and the clutch pedal was stuck to the floor. Pulled the pedal back from the floor, all was fine drove it up. Its done it again, twice since then.. any ideas?
Last time it happened I was in neutral, and couldn't get it into gear, noticed the pedal was stuck again.
mazdaman82's avatar
mazdaman82
sounds like you are loseing pressure and may need a rebuild on the master cylinder
themdot
its the slave cylinder on the side of the tranny. They cost like 10-15 bucks,it will feel mucho better.
mazdaman82's avatar
mazdaman82
yay that too
otterboy47's avatar
otterboy47
Sounds like you got a slave that don't like to work! Okay that was not very P.C. of me. Ha Ha! Really, check out that Slave Cylinder.
xjoewhitex's avatar
xjoewhitex
So since everyone gave the same answer, I think I will go with that lol. So its located on the trany itself? Or beside the brake master cyl?
kia swap
last post by Brody +1y
51
