For you audio guys out there do you know of a calculation or trick to know how big of alternator you need for a certain amount of wattage output?
ragecc
Watts divided by voltage should show amps being drawn.
1000 watt amp divided by say 12.5 volts is drawing 80 amps. That will give you a idea because that is figuring the amp a max power constantly. There may be a better way, that's just what I was able to come up with.
