take them to a machine shop, you will be happier, less headache. I think someone said most places charge like 60 or 70 bucks for all 4
midnightmike
machine shop charged me 20$ a wheel, 80$ to spin a machine and that was 13 years ago, i imagine its gone up from then
well there is a super cheapy way of doing it and a friend and i did it
its ok if you dont plan to have wheels hub centic, which my wheels have a 4" bore and the mazda bore is 3.75" and i havent had a problem and ive had the wheels for years
first off, the mazda hub size 3.75" and the eskies are 3.25"
tools needed:
a good electric drill (not battery powered)
a 3.25" bi metal hole saw
a 3.75" bi metal hole saw or bigger to be safe like a 4"
and penitrating oil
now what you want to do is take the 3.25 hole saw and put it inside the larger one (i.e.4") and feed the pilot bit through them, and fasten the locking nut on which will lock everything together, the pilot bit wont do anything but hold it together, but the 3.25" hole saw will be the guide to drill the hole centered in the rim
put the bit on the drill
place bit in rim
and start drilling, but keep the rim on a solid flat surface and keep the drill as straight as possibe
might want someone with you when you do this to keep lubercating the bit as you drill, to keep the bit cool
let me know if you dont understand anything ive said
roger26i
or u can grind ur tabs down much easier and cheaper
dwinward
Thanks midnightmike thats what Ill do.
binatang
Grinding tabs is alot quicker and easier. Done mine last night, and took about 2 hours total. And thats with ALOT of breaks. Rear is kinda painful, but the front is super easy! Had both fronts done in ten minutes!
