Mazda Engine General \  Rear diff question
Rear diff question
views 1304
replies 15
stantheman   +1y
Ok, now Ive got a question for everyone. I just heard as a rumor that you can narrow a mazda rear diff an inch, cut the axles an inch and still have enough splines to use the factory axles? Has anyone ever done this? Please let me know!
Heres the quote I got just incase that didnt make sense. "I've heard RUMORS that you can take a factory Mazda rear end and narrow it an inch and there's enough splines on the factory shaft to allow you to cut them down"
stantheman   +1y
Nobody?
dezionz   +1y
why would you ever want to only take off just a inch? if your going to do that much work to narrow a rearend do alot of inches and add the mickeys and tubs
stantheman   +1y
That may be all I need to do. I was just curious to see if any one has done it to see if this rumor is true.
v8mazda4ever   +1y
I guess you could do that but you could just get the rearend out of a nissan pathfinder and put it back in the rear. its like 1 1/2 inches shorter than stock on each side and comes with disks in the back which is a nice up grade.
stantheman   +1y
That would be awesome, what year pathy or are they all the same?
v8mazda4ever   +1y
I got mine out of a 1994 nissan pathy v6 auto.
stantheman   +1y
Sweet, Im going to look into it as soon as I get my bonspeeds and get them measured. Thanks for the info.
stantheman   +1y
does 2wd or 4wd matter on those? Just want to make sure I find the right one.
v8mazda4ever   +1y
I do believe that all pathys are 4x4 and the nice thing is you have alot more gear ratios with that rearend too. No problem bro.
