power steering leak help..
ham
Hi.. I'm new to this forum. I just picked up a 92 b2200 n the power steering pump is leaking from the nut that holds the hose on. I thought it was bc it didn't have any crush washers so I added one before n after the hose n tightened the nut. Still leaking. Mazda couldn't help me, they wanted me to buy the whole pump. Advanced auto parts has a seal rebuild kit but they have no clue what comes with it n takes a wk to come in. Can someone here point me in the right direction pls? Thank you for taking the time to read n your help..
Replace the pump
E
emjay
for the power steering assembly you have a tapered fitting that makes it seal. I'd try to clean the threads on the PS pump and lines before buying anything. Also, there is a teflon tape that is designed for petrolium products. If it's just leaking at the threads then I'd give this a shot before buying a new pump, or a new line. Pics would help.
ham
Thank u for ur help guys. I finally got it. I replaced the oring on the line n put a washer on that nut n it seems to have done the job.
mazdawg(mikey)'s avatar
mazdawg(mikey)
Great! Glad you got it fixed and thanks for letting us know your solution and your outcome
ham
No problem. Thanks again.. so I just picked this truck up not too long ago n I'm trying to work out all the bugs to get it on the road. Drove it around a few miles yesterday n noticed the gears we sticky.. I pulled the shifter out n noticed lots of shavings in there. Looks like I'm going to need a tranny asap. :\
kia swap
last post by Brody +1y
51
