Mazda Engine General \  clutered engine bay..
views 999
replies 4
draggin92   +1y
what can i do to remove all the vac. lines and all i am about to order a weber carb kit
is there a write up anywhere whowing what all can be removed? any help would be nice that... i have looked around and didnt find what i was looking for...
my inner fenders are cut out and all the lines and all on the pass side just look bad i want to remove all the sensors and vac well anything not needed.... its pre 96 so no need for emission as long as it will runs right is all that matters..
paparoach1983   +1y
there is a write up on the carb its called the instructions. lol. sorry . the weber carb kit uncluters all the sensors on the passenger side if you look at leland (91extcab) suki project he did a really good job showing enough pics to let you know how to get all the wiring cleaned up.
this is a link to his build thread he has almost made a clean your engine bay thread out of it hahaha good luck its easyier than you think
draggin92   +1y
thanx ya i was looking at a few builds and they all said almost all on the pass side can be removed.. and have been looking at all the pix people put of when they did there and marking mine. and trying to get them all marked b4 i start ripping it all apart.. i have wire tucked a few cars and this one doesnt look all that hard, i was mainly worried about all the vac. lines thanx for the help... the carb will come soon as i find a good deal if i can run on stock and cleaned up im happy with that..
the tread i have been looking at that helped alot was tuna's
this one here tuck#p304167
91extcab   +1y
Mine is fuel injected so the process was a little different for me, but same general idea. I've heard that almost everything on the passenger side can be removed, including vacuum lines cause most of that is for the factory carb and emissions stuff. I had to hide most of my stuff cause it was still needed for the fuel injection to work. The wires in a 2600i on the passenger side all run from the computer to the fi manifold and injectors.
draggin92   +1y
soon to have a clean bay.. weber and pacesetter ordered..
