Mazda Engine General \  Can I remove...
Can I remove...
views 539
replies 2
codymac08   +1y
Can I do away with the air injection on front of the air cleaner? I can see how pumping exhaust into the air cleaner is efficient. If I can do the what is the best way, I want to keep the stock carb if possible.
Thanks,
newbiet   +1y
It's actually pulsing fresh air into the exhaust to help lower HC and CO in the emissions. So if you don't live somewhere that test then yea pull them out. The ones on the mani can be plugged with lug bolts.
slamsonthedawgmaster   +1y
And if you take the flat plate that bolts to the bell housing as an exhaust support and turn it diagonally it will bolt over the lower tube mount very cleanly and easily
