Mazda Engine General \  any tricks on refinishing wheels? chrome peel, want to paint
views 678
replies 4
jimbeater   +1y
hey guys, i picked up a set of caddy escalade rims for about $170 after i sold the 2 decent tires out of four that came on them right away. the chrome is peeling off of 2 of the 4 wheels. i want to paint or have them powdercoated, likely paint because i have had good luck with a good finish on rims in the past, and it's much cheaper.
#1 reason i wouldnt rechrome? i dont generally like shiny things! i like black chrome though, but likely painting them a clean gloss white.
any tricks for pulling the existing chrome finish? as it is partially peeled off of the face of 2 of the rims, and some lifts on the plastic lug covers as well. just pull what i can by hand and then wirewheel the rest at least flat, then some glazing putty to smooth?
jimbeater   +1y
any ideas?
jjm5150   +1y
Not quite sure have you tried anything that will take paint off?
jimbeater   +1y
well, the chrome finish is coming off as a 'plating'. i suspect i have to do what i can to get it all off, and then body work
dragaddict   +1y
If I were you I would media blast them, then put a good coat of epoxy primer on them and then single stage over the top of that.
