Mazda Engine General \  Anybody know if I can remove the pulsation damper?
views 3131
replies 12
following 6
mazda-man   +1y
Has anyone ever removed the pulsation damper. Is there actually that much pulsation in the fuel system? Do all EFI systems have one of these? Mine is leaking again for the second time.... and there aren't any of these left in the junk yards around here. Thanks everyone!
mazda-man   +1y
Sorry...made a new album today and forgot to select "public" for the pics. Should be there now
sincitylocal   +1y
Isn't that the fuel pressure regulator?
mazda-man   +1y
No the pressure regulator is on the end of the injector rail, it has a black vacuum hose hooked up to it.
jenko   +1y
You can buy new ones champ
It's just fuel connections so you should be able to find something that'll fit.
If the manufacturer added one I'd say keep it around, they're not a silly idea.
It'd still run etc but why chance it
jenko   +1y
actually.... check the ford probes etc for the same part.
I'd imagine they are the same... but perhaps research that one first
88b2t   +1y
Probes don't have it.
If it's leaking from the seal, that is part# N304-13-291 and it's readily available. $3.23 from your local mazda dealer.
jenko   +1y
And that is why this website is so sweet!
zspeed10   +1y
With the cars I work on...
Pulse dampeners are important. They'll keep the fuel pressure even, which keeps your idle and acceleration even.
You could research injector latency and its relation to fuel pressure if you want more information as to why the pulsation dampener is important.
Short story is, the injectors cause the pulsating, the pump pumps at a relatively steady rate and fuel will not squirt out of the injectors in a steady stream without it.
91extcab   +1y
That sir, is a fantastic knowledgeable answer to the op. I applaud you.
