Mazda Engine General \  Help me locate coolant temp switch
views 683
replies 4
beigebomber   +1y
I have 2.2 1987 b2200, Chiltons says left side rear, under engine block, but I don't see anything there. I also saw what may be it; attached to the underneath of what I think is the thermostat. A picture would be great. Thanks
Cusser   +1y
Yes, that's the coolant temperature sender, just under the thermostat (on these the thermostat is passenger side of engine but front, not rear, is vertical and faces the passenger fender; follow the top radiator hose to the engine, and it's inside that water outlet that bolts on). Sometimes the wire gets knocked off of these. If you are getting a replacement sending unit, make sure it looks like the one in there, I've seen listings with different wire connections.
beigebomber   +1y
Thanks. So I compared the two parts and both are similar. I tried to pull off the female end, but it moves just a bit before its really difficult to pull off. I want to try to pull really hard but don't want to break it.
Is there a trick to get that plug off?
Will fluid come out when I take it out?
beigebomber   +1y
So I got the switch off. The repair manual says to torque to specific inch pounds, can't remember what it was. How important is it to get that exact?
I don't have a torque wrench.
zaccutt   +1y
People have done worse then missing torque specs. If it doesn't leak and you didn't strip it then its fine.
Zac
