Vacuum problem?
soldier4god001@yahoo.com's avatar
Vacuum problem?
soldier4god01's avatar
soldier4god01
My truck keeps idling high, the idle screw isn't even touching the plate it is out that far, I just had carb rebuilt and replaced all the vacuum lines and sprayed around all lines and fittings to check again. I can bump down the timing but then it runs awful, and ideas?
topless
I don't have the answer to your ? , just wanted to comment on your name !, cool not many will take a stand!
soldier4god01
Thanks man, I do my best just thank full!
topless
Hey guys I know nothing bout these carbs! But could float b set wrong? And are you 100 percent sure ask vacuum
lines n correct place?
soldier4god01
As far as i know they are, I cant find a good diagram that shows all of it clearly from the diagram under my hood its correct but it looks like its leaving out a few lines?
topless
Yours b2000 2200 or old school 2600? Where you located?, my 2000 motor all stock 4 now maybe go by it!
soldier4god01
84 b2000 , Greenville sc, if you have one could you post a pic of the vacuum system?
topless
Mines 87 model I think everything different! There's a few guys on here very knowledgeable on pre 86 Mazda! , if mine the same I'll be glad to take pics!
kia swap
last post by Brody +1y
51
