Camming
soldier4god001@yahoo.com's avatar
Camming
soldier4god01's avatar
soldier4god01
Im thinking about putting a mild-heavy cam, what can the stock head hold? What upgrades would i need?
guam671
I'm thinkin the same thing . I'll be looking out on this thread . ^0^
E
emjay
what other work do you plan to do to the head? just throwing a different cam in there isn't going to do much of anything on a stock B without other mods.
sincitylocal's avatar
sincitylocal
Yeah, you'll have to port the snot out of it and put bigger intake valves, but still won't get the power you'd expect.
jeff115
why does every one say that?
b22trk91's avatar
b22trk91
Bigger piece of bread = more spread lol...cams have lobes on them and when you put a "big cam" in the lobe sizes are increased from .715 to .845 (hyperthetical numbers) these bigger lobes push on the intake/exhaust ports holding them open longer (lobe duration) a standard cam will require so much air to fuel to compression timing etc...
So this means your gonna need more air if it wants it.. which means more fuel obviously
Opening up the valves means springs compress which means they lock or breakdown... a tough head for bigger ports lifters springs valves cam gear
Everything u do to any engine is a compromise this is a basic way of understanding the theory behind how it works n why "all people say that"
hocbj23
Call Paeco Industries in Birmingham Alabama. They make aftermarket cams, lifters,valve springs,etc for 2000/2200s.BJ
hocbj23
Heavy as in weight or heavy as in lift and duration?Fits both 2000/2200?Thanks.Happy New Year-be safe out there.bj
E
emjay
R90Baron has a delta stage 2 cam in his, with a pacesetter, ported head and intake, and a Weber 38. He lost some low end torque, but can pull through 5500 RPMs on his setup. I plan on using a state 1 cam eventually, a regrind can cost around $100 with a cam provided. He didn't do any valve work either, stock on the valves and springs.
soldier4god01
Heavy as in duration, not sure about the 2200, 2000 is an 8 valve and 2200 is 16? Not positive about it. Sorry, wish I knewmore
kia swap
last post by Brody +1y
51
