Mazda Engine General \  Rear axle inner seal replacement
views 695
replies 1
following 2
befarrer   +1y
Is it possible to only replace the inner wheel seal on the rear axle without damaging the outer seal?
Also, am I correct to assume that the wheel bearing has to be pressed off of the axle shaft to replace the outer wheel seal?
87forever   +1y
Yes you can remove the axle shaft and just do seal inside the axle housing.This seal is most prone to leak as the backing plate proves this on most b trucks I have seen in the junkyards.Ironically I do believe the seal in the housing is considered the outer seal (idk why) but,just remove and double check either here OR " target="_blank first forum has parts list stickied for that seal you need.Axle will pull straight out,and I did not need a puller to remove.Take seal with you if unsure to store.Since the inner/outer maybe diff.Hope this helps and not sure if mt has that listed on parts,so many post going on recall.
