how mutch gear oil in a 5-speed
chrismp91
im wantin to drain my tranny and put fresh 80/90w vavoline gear oil in it how mutch do i need to fill it properly as in how many qurts? maybe 5 or 6?
befarrer's avatar
befarrer
I think it is between 2-3. It gets filled untill it runs out the fill plug on the side of the tranny.
87forever's avatar
87forever
It is 2 quarts and you should fill it with about a quart and half and add in small increments.You want to either fill the fluid with small finger inside the fill hole or have a slight drip coming over(not a river).Overfilling is not suggested as with engine oil capacities.Pretty easy and I use a long funnel with a extended tube to fill from top side at the firewall.Then double check after filling to 1.5 quarts then top up to the 2qt point small drip or feel fluid inside fill point.Just drive your truck some to heat up fluid for a good drain out,then refill.Btw the rear end runs the same gear oil and hold about a quart in a half on memory.I run 75w90 myself.
chrismp91
so whats best weight to use 80/90 or the 75/80? i never under stood what the weights are or diffrence betwen them all and thanks for the info ill get a 5quart jug and just mesure out for both rear end and tranny
Cusser's avatar
Cusser
Most use 80/90 unless they live in a real cold climate.
I pump in from underneath, there are pumps that screw into the gear oil bottles.
HINT: always loosen the fill plug before draining !!! I think you'll know why. Also: a 23mm socket (Lowe's, O'Reillys) is the right size for some of these.
Cusser's avatar
Cusser
Warm up the gear oil in the house or sun, so it will be less viscous and pump easier.
Change the rear axle gear oil at the same time, you've got all the stuff there.
longbarrell
how do i swap out the stock mazda bumper with a toyota bumper and valance?
kia swap
last post by Brody +1y
51
