Mazda Engine General \  1992 b2600 4x4
1992 b2600 4x4
views 711
replies 3
jae w   +1y
About to go and pick up a 1992 b2600 4x4 that has been sitting for 5 years, I know it will need a new battery, oil change and tune up any other things I should check out before I make a journey back home with it? Also are all 92 b2600 fuel injected or did they come carb'd also
sincitylocal   +1y
They all(92) should be EFI.
Your tires are going to fall apart. I'd put it on a trailer.
berryserious   +1y
Check your grounds, fuel pumps tend to go bad after sitting awhile.... Change brake fluid, the absorb water... And tend to rust the brake lines from the inside out... Definately trailer it if possible
Cusser   +1y
If it runs and seems OK, then I'd change all the fluids and filters. Includes coolant oil, gear oil, differentials, transfer case...and new tires
