Mazda Engine General \  air ride freezing up??
views 957
replies 6
chrismp91   +1y
so sence its got alot colder in the south at nights i air my truck up on the way to work and lay it out cause it looks better lol but when i get off early morning hours my compressor leader hose is frozen and it wont push air in the tank...any deas?? was thankin about usin the hand warmers to wrap arond the ends to keep it warm or even hurd of air brake antifreeze????...maybe just not lay it out lol
baha   +1y
Yeah there is something like air brake antifreeze but do you have a water trap on your system?
lowlyfe   +1y
Back when mine was a daily driver the valves used to freeze up on me and let the car air up so I kept a small pipe in the trunk and a light tap on each of them was all it took to free them up.
I wanted to use some of the air brake anti-freeze but was worried about the valves not sealing shut when I needed them to, but now that I think about it, semi trucks wouldn't use the stuff if their brakes depended on it lol.
kovz   +1y
A cap full of air-brake antifreeze in the tank will do the trick.
chrismp91   +1y
Ya I have a water trap but its freezing at the check valve and sence its freezing there will that air brake antifreeze even help?
kovz   +1y
So your compressors won't fill the tank because the check valve is froze? Maybe put a few drops of the antifreeze stuff in the water trap so it goes through the check valve into the tank and doesn't let it freeze up.
chrismp91   +1y
well would I half to put the water trap on the compressor then the line? I have it at the tank now that the line runs into it
