Mazda Engine General \  lights on warning buzzer
views 833
replies 3
hocbj23   +1y
I seem to remember that a few years back someone on here showed how to build a simple Buzzer that went off when u shut the engine off with lights still on. I made one,it worked great until this week.Now I need the instructions so I can troubleshoot and see what went wrong.At the same time the buzzer failed the dash lights went out so I suspect they are somehow connected.Anybody?Thanks mucho.bj
dan woodland   +1y
It might be your dash dimmer gone bad. You can remove the switch and test it with a volt meter (set to continuity) and turn the wheel to see if you can turn it on and off.
To take off the bezel you only have to remove the 4 screws under the top and bottom lips.
Cusser   +1y
Your dash lights could be off because of a bad dimmer wheel switch.
Or: your dash/cluster lights, the tail lights, and the parking lights are all on the same circuit. If those are out, check the 10 amp fuse labeled "TAIL".
I think your two issues are definitely related.
Others: you can buy such a warning switch commercially. Search Lite Minder on Google. I've used these in my B2200 and in my '71 VW for decades (the one in my B2200 I transferred from my '79 Toyota truck).
hocbj23   +1y
Thanks gentlemen.Fuses are all ok. I seem to remember when I built the buzzer it was connected to the dimmer wheel so I suspect that may be the culprit.They are notorious for going bad and I have a couple of spares so I think I will replace the wheel before I try and build a new buzzer.Thanks again and glad to see the site is still here and "buzzing" along.Lol.bj
