Mazda Engine General \  Turn signals not shutting off automatically
views 772
replies 4
spacemonkee23   +1y
As the title says, when I click my turn signal either direction and turn my wheel from lock to lock, the signals don't shut off no matter how much I turn the wheel either direction they stay on. This started happening when I replaced my plastic steering column cover because the old one was broken. I tried taking the cover off and looking around for something out of place but everything looks ok. (same issue with the cover off) I did tighten the clamp screw on the signal switch because it was loose, maybe it slid out of alignment? Is this a possibility? I will mess with it some more but I keep forgetting its broken and my signals stay on people honking to let me over, haha.
Thanks
Cusser   +1y
Tell people you're precocious, just practicing for old age in Arizona. Most folks just don't use turn signals here (saving them for old age?)...
jiffyzx6   +1y
My guess would be if you take your steering wheel off there is a plastic ring with two nubs that go into the back of the wheel, that's what shuts them off I believe.... Worth checking out
spacemonkee23   +1y
Thanks I'll Check it out.
dan woodland   +1y
It looks like the part is $5 at the dealer.
Part number... BA2966126
