have an 87 B2200 and need a part that no junkyard has...
a1966vw1300@hotmail.com's avatar
87b2200pa's avatar
87b2200pa
need a drivers door latch.. have it tied shut with rope... also wondering why the clutch whines sometimes when i push it in and it is near impossible to shift.. then release, pump it and it'll work fine again..
dan woodland's avatar
dan woodland
sending PM
87b2200pa's avatar
87b2200pa
replied via PM
Cusser's avatar
Cusser
1. Whining/noise when you push in the clutch is typically indicative of a bad throwout bearing.
2. Tough shifting is often because of bad clutch master and clutch slave cylinders, they don't seem to be too "sturdy" over time on these trucks. I've had my '88 B2200 19 years this month, and replaced both several times. Your choice whether to go quality factory replacements or the lifetime warrantied ones. Luckily, these are not too difficult at all to replace. But also check the two flexible clutch lines for leaks (I've had one leak).
