Mazda Engine General \  ALTERNATOR OVERCHAGING
views 1086
replies 9
following 5
pabartelt   +1y
My alternator is charging at a rate of 16.9v at idle 800rpm my battery is reading 12.4v so that's right but I thought 16.9 was high could there be an issue?
the reason I checked it was that the battery charge light came on in the dash. it sounds to me like the regulator board might be bad.
anybody have any idea's
spacemonkee23   +1y
Yeah that seems high, looks like its time to replace it. 15V+ is too high, roughly 14.7V is the highest you should see. Hope it doesn't fry anything.
pabartelt   +1y
there is a regulator board on these trucks right?
I didn't see anything that looked like it anywhere?
Cusser   +1y
I believe that you'll need a complete new alternator.
I once had a 1979 Toyota truck and one day all the lights got bright and burned out except for headlights and flashers. So I had to replace bulbs as well as alternator (and that may have had a separate regulator too, can't remember).
spacemonkee23   +1y
The voltage regulator is internal, its a complete unit. Get a new one or swap to a more powerful one like a GM alt.
pabartelt   +1y
thanks I appreciate it.
Found a reman for about 85 so im gonna do that.
sincitylocal   +1y
Don't condemn the alternator before having the battery load tested!
Bad batteries can cause all sorts of goofy gremlins.
pabartelt   +1y
Ive never done a load test on a battery. ill have to youtube that one. I checked the battery (two months old by the way and not a cheepy) and it was showing 12.4 with the truck off. I have until Friday when the new alt gets here so ill do a load test.
I have to use it for the short 10 min drive to work and back but I won't drive it other than that until I get the new one in.
I hope nothing fries up on me.
mazdatweaker_2   +1y
I think you have a bad battery. Or maybe on the outside, a bad cable that is corroded internally. Replacement cable ends are a place for trouble on 20+ old trucks. Given that your battery is only two months old it should be showing more than 12.4 volts. I'm thinking you have a dead cell and the alternator is trying to push voltage past the dead cell. Or the corrosion in the cable. Each cell in a 12 volt battery at discharged state should be 2.1 volts (2.1 x 6 = 12.6) and the alternator is going crazy trying to get the battery to 13.6.~ 14.2. All the extra voltage building up in the alternator is being bled off as heat and that will take out the alternator.
With the engine off, you can do a simple load test by turning on every electrical draw for about three-five minutes and checking your voltage. What that does is drop off the surface charge to something a little more normal for the battery, I think you're going to see the voltage drop to around 11 VDC on yours, a sure sign that the battery has a weak cell.
Hope this helps.
sincitylocal   +1y
Most chain parts stores will load test the battery for free. A decent shop may also do it for nothing.
Call around.
