Mazda Engine General \  interchangable ignition switches?
views 515
replies 3
b-22 bomber   +1y
hello I was wondering if anyone can tell me wether an ignition switch from an 88 rx-7 is interchangeable or will work on my 89 b2200? or is there anything I can do to make it compatible? please help as I have ben without my truck for over a week now. or if I ran toggle switches, would I run the the ign. switch wires to the toggles the same as they are grouped together into the connectors from the factory? thank you
Cusser   +1y
You're contemplating really Mickey Mouse instead of getting the correct replacement ignition switch (electrical part).
I advise the latter path.
b-22 bomber   +1y
do you mean like going with a newer switch from a newer vehicle? if so do you.have any recommendations for what else I could use? I can't afford anything but having a harder time even finding one. a rock and a hard place are cushions compared to what IM stuck between. i am at the point of desperation for any info or input.
vsawmike   +1y
I have a 92 B series ignition switch with wiring, key and door locks to match. holla
