Wiring Harness ?
Wiring Harness ?
oldschool
I just recently found out that the MAIN harness in my 92 B2200i is messed up pretty bad...My truck is a 5spd..Do you guys know if the B2600i harness will work on my truck since it is also fuel injected?....This is the main harness NOT the engine harness...This is the one that winds through the dash and goes in and out of the interior fuse box and then into and around the engine bay...thanks
X
xxchromeghostxx
Not too sure, i know on chevy trucks you can inter change those harness's as long as all the same options are there. From burbuans, tahoes and c/k trucks. But this is chevy vehicles. But i think the same may apply. If its all can find dont hurt to trt, you may be able trade it on here for the one you need.
sincitylocal's avatar
sincitylocal
It should work okay... BUT... Make sure you check your multi-switch plugs. If you have a turn signal, or headlight(can't remember which) connector with 4 wires, you need to make sure the replacement harness also has a 4 wire plug.
There are some trucks with 4 wire plugs, and some with 5 wire plugs.
X
xxchromeghostxx
I believe it is the turn signal, because of the different intermittent an reg wiper modes? I could be wrong but i think thats where the extra wire would come in.
kia swap
last post by Brody 12 mo
51
