What's the difference in 89 to 90 b2200 brake booster?
rcogan
I have noticed that the brake booster from 198 to 1990 apparently changed(listed different, different prices)
if you look up a 89 b2200 the booster has the 90degree vacuum nipple instead of straight one like on the 1990)
Visually that is only thing I can see different, but of course none of my local pull a part yards have any of these trucks that I could pull one off of to compare or even test, and no local parts house has either in stock, being told I would have to pay for booster, when it comes in I could see if its gunna work, if not, they will refund my money(as long as I don't install it)
I don't have that kind of money
Can someone tell me what the difference is?
Want/need to know if I can use a 1989 booster
rcogan
Well, did some research and the booster diaphragms from 86-89 automatics are same as 90-93 boosters.
86-89 manual trans diaphragms are smaller
From 86-93 they all use same master cylinders(manual trans and auto)
The back mount bolts(inside of firewall on pedal side) on the manual are obviously spread out farther, in a "rectangular" shape, so it won't bolt right in
The 86-89 auto "appears" very close, I got O'Reilly auto parts to order me one, going to see if it bolts in when i get home, will update
Post was last edited on Jul 23, 2014 06:15. Edited 1 time.
mymmeryloss's avatar
mymmeryloss
Interesting. Keep us updated
Sent from my iPhone using Tapatalk
rcogan
now remember, info provided, along with pictures, are from napa and oreillys computers, a few things i have found on internet, a few pictures from individuals and the small amount i have actually dealt with thus far..anything to add, feel free too, may come in handy to someone reading this later on
this is the 86-89 automatic transmission booster.
" target="_blank" target="_blank" target="_blank
90-93 brake booster(no auto or manual difference)
incase anyone was curious, this is the 86-89 manual option
so far only difference is the vacuum port is bent on one, and the price is alot better on the 86-89
firewall mounting surface bolts and pedal pushrod are the same
gunna try to mount it this afternoon when i get off work
rcogan
Well, got it bolted in and hooked up, fit like a glove
Works perfectly fine so far, only thing I have found so far that is different is the vacuum line with the valve in it(difference is the way it comes premised)
Literally seems only thing different is the vacuum port is at a 90 instead of straight out
kia swap
last post by Brody +1y
51
