My 1992 B2200 hates the weather
turboboost
Here's the scoop.
Truck has 134,000 km on it, one owner truck, EFI, automatic. It has been great to me so far except for a few small issues here and there. When it's -20 degrees outside the truck starts perfectly plugged in or not. Even the other day when it was -35 Celsius outside it started no issues. Now in the past week the weather has been warming up causing everything to be sloppy and wet on the roads. Today I go to start my truck, it is a paltry +2 degrees outside, snow is melting everywhere etc. etc.
Truck won't start. Will crank and crank and crank, maybe occasionally "popping" or sounding like it's firing on a cylinder or two. It did this once before when the weather was similar (ie: right at the freezing/melting point). Last time I just let it sit all weekend and it started no problem the following Monday when it was -20 or so outside.
Why does it do this? I'm assuming it is just moisture getting somewhere it shouldn't... I quickly popped the distributor cap and it seemed dry and fine in there. And I can also smell fuel from the exhaust when I'm cranking.. I didn't really have a lot of time to troubleshoot this morning before work so I just ended up taking my Toyota in today. But I'm kind of getting stressed out about the truck not starting and I can't be driving my Toyota very often because it's got bald all-seasons on it and it's kind of scary to drive on a slippery road.
Has anyone had this issue before? How did you rectify it? Is it a common issue with these trucks?
Thanks in advance for your help,
Derek.
mazdatweaker_2
Maybe your coolant temperature switch or the plug has gone flaky. I think it is located behind the timing cover near the thermostat. It's visible from the outside.
Have you tried to crank the motor with the throttle at the floor?
kia swap
last post by Brody +1y
51
