My b2200 runs rough just at idle
Z
Z
zrmiller
so i have a 93 b2200 it has the stock carb. i tried cleaning it and i did a tune up but it still runs rough! but its just at idle once it gets moving its smooth as silk i think its the carb what do y'all think? i have a weber 32/36 siting around i think i will put that on there with the adapter plate and see if it fixes it. i jet wanted mother opinion to see what else it could be. thanks any help would be appreciated.
Cusser's avatar
Cusser
I'd snug up all the carb attaching nuts, and check/double check for a cracked or loose vacuum hose/fitting (there are a zillion of them). Don't overlook hoses going to bottom of air cleaner either, or the thermo valve under the intake manifold.
befarrer's avatar
befarrer
I had a rough idle on my 88 when I had it, was shaking at idle. It turned out to be a vacuum leak, but it was a faulty vacuum valve. I started pinching vac lines with needle nose pliers when it was idling (after verifing no hose leaks), and when I pinched one hose, it idled smooth all of a sudden. Out came a screw that fit in the end of the vac hose, and off I went lol, it was for an emissions device, and we don't have testing here.
mintyjfresh
Wow I've gotta try pinching off my hoses maybe thanks for info
kia swap
last post by Brody +1y
51
