93 b2200 clutch problems
Z
Z
zrmiller
just put a new clutch set in my b2200 but the clutch fork will not move all the way back even if i try to force it i did have to remove it to install a new throw out what could it be.
sincitylocal's avatar
sincitylocal
The snout that the bearing slides on may be worn, and have a ridge that stops the bearing.
Cusser's avatar
Cusser
Disc in the correct way?
mercilessltd's avatar
mercilessltd
I had issues at first with the bearing sliding on the fork correctly to allow the bearing to slide back on the shaft. I wasn't using a new bearing so it may have been worn.
kia swap
last post by Brody +1y
51
