HELP! Dash and taillights not working
rynnbali@gmail.com's avatar
rb86's avatar
rb86
Any idea why my taillights and dash light wouldn't turn on? I've checked the fuses under the hood but they all seem to be fine. Is there something I'm missing here?
kimballs's avatar
kimballs
What year and model? mines a 93 2200 and it has a secondary fun box in the cab under the steering colum it will be the top right fuse if it's your dash lights and rear.
Cusser's avatar
Cusser
It's a separate circuit in the headlight part of the combination switch, this happened to my '88 a few years ago, not uncommon on these trucks as they age, and the headlights themselves will still work fine (a different circuit).
See these links, to repair or replace your switch (there are two types of switches, very similar):
rb86's avatar
rb86
Thank you, does it apply to the 79-84 models as well?
Cusser's avatar
Cusser
I don't know; you'll need to use Mr. DC test light or Mr. DC voltmeter to determine that on yours.
Since your headlights work, you've got power into the headlight switch; a quick test with the switch in that on position should tell you whether positive voltage is in that wire to the running lights and instrument panel. In general: if the fuse is good, then likely the switch, because too much of a coincidence for all those circuits to go bad at once, and the common functionality is that secondary circuit of the headlight switch. So that's where I'd put my bet.
kia swap
last post by Brody +1y
51
