Mazda Lowering Static \  sohc fe - sohc fe/t swap help !!!
views 728
replies 2
hursey69   +1y
i want to convert my fe carby motor to a fe/t. what parts do i need to do the conversion????
jmuse8482   +1y
Okay, So........ Your going to need allot ! ! EVen if you do a draw through setup your talking allot of Time,Labor,Money. If your trying to do a turbo carb setup, your cheapest bet is a weber side draft carb. Blow through units are EXPENSIVE. Then you need a turbo with Carbon seals (a whole other issue). Turbo manifold you can source from a turbo MX6 or Probe GT 1st Gen. Fuel pump Ext.... EFI : Turbo, Stand Alone ECU, INtercooler, Fuel Pump, Injectors, Custom Intake (im not aware that they ever made a EFI 2.0 unless the kia fe sohc fuel inj crap will work), BOV and the list goes on. If you are 100% sure that you plan to go through with this i would be more than glad to help you out the best i can. But, if all your wanting is more GO POWER, Horse Power Per Dollar your best bet is to source a 1st Gen (95-98ish) Kia sportage. Get the whole engine out wiring harness,ecu, flywheel, clutch,engine mounts and all.... Bolt it in, wire it up. 140hp. Virtually no Drama, And no broke transmission either unless your John Force..
1hotdawg   +1y
It's been done, use the search feature and you can probably find all the info you could want by people that completed the swap.
