Mazda Lowering Static \  Needing some help, pic
views 727
replies 5
huskerdually   +1y
I need to see a transmission crossmember for a manual tranny, ours is a auto. I thought the tranny crossmember was a bolt in deal, but ours is the same one that the torsion bars mount to in the back. So I could really use a pic of what a manual tranny crossmember looks like.
I also need a really good wiring diagram for a b2600i, any help where to find one would be great.
ulrich   +1y
huskerdually   +1y
I need to see where it attaches to the frame. Does it bolt in?
mark2.0   +1y
Bolts on with two bolts/washer/nut combos on each side and then two bolts directly underneath the tranny that holds it in place to the crossmember.
huskerdually   +1y
Ya the automatics use the crossmember that the torsion bars bolt to. It must be a long tranny, the ford tranny doesn't even reach it. I remember when I swapped the 302 into mine 15 or so years ago I was able to use the stock crossmember, but it was a manual. I think maybe I will try and find one to modify, will have to see what I can find.
huskerdually   +1y
Oh and thanks for the replies.
