Mazda Lowering Static \  timing advance
timing advance
views 833
replies 5
following 5
stevewfo   +1y
How much timing advance is going to be to much? I am running a weber carb progressive, and have bored the block .020 over. it is runing at idle with vacuum advance conected and 25 degrees of advance. I was curious if any one has one set any higher. i am trying to get all the power i can out of the motor. it wont hold much over 80 on the hwy.
stevewfo   +1y
I forgot to tell you it is a 86 b2000 manual with no smog or accesories
oo7bob   +1y
no one knows where you live. thats a big deal. if you cant keep up 80 kph, thats a problem. if you cant keep up over 80 mph, thats because its a truck, not a vette.
tucknrimmaz   +1y
25? My old 2.2 with a weber, cam, and header would hold 105mph. My timing was set at 10 degrees BTDC at idle.
charlesskelter   +1y
My B won't go past 85. But she'll hold steady at 75 all day. I haven't checked the timing at any point though.
Mine is also an 86 B2000. Not running the computer, some smog stuff removed, still need to remove the rest.
mazda-man   +1y
25 degrees is way too far. That is probably to the point that you are causing a loss of power.
