Mazda Lowering Static \  weber carb install help
views 774
replies 1
following 2
k-shaw   +1y
installed the weber. pulled a bunch of vacuum/electrical lines in a frenzy, not sure if i have the right ones hooked up, or the right ones plugged, could find no schematic. it actually started, and ran, sounded nice, not once, but twice...then sputtered to a halt. has a new fuel pump and seems to be getting fuel. relatively sure i've got the electric choke wired, (is that to get power with the key in the on position?). replaced cap/rotor/pickups, plugs/wires. could the coil be firing inconsistently? is there an accurate vacuum/electric diagram available?
Cusser   +1y
Wow - you sure learned the hard way not to do too many things to a vehicle at once.
So I think you're back to trying to use aerosol starting fluid into the intake, to see if it runs even a little, do several times. Spray some in, floor the gas pedal, and crank. If it runs a little, then most likely a fuel delivery issue.
If not, then a spark issue.
